We have a point feature which is editable and is not m value enabled. Can add new features and edit attributes for existing but cannot move or edit the geometry. The features do not have m values.
Mike,
are you the author of this feature service? When you go to the rest endpoint what are the allowed capabilities for the service
i.e. Capabilities: Create,Delete,Query,Update,Uploads,Editing
Do you see any errors in the web console. Is it only this one layer?
There are no errors. I've propped up another web appbuilder app with another feature class and have same result. The point geometry moves but when zoom in or out the point moves back. Can successfully edit geometry in web map which is consumed by web appbuilder application and app created using other templates.
It sounds like you need to place a call to tech support and they can determine if this is a bug or not.
Hey Robert thanks
