Imagery and Remote Sensing is the forum for you. I think you meant georeferenced? I suggest removing your georeferencing and starting again from scratch, being careful with setting up your control points (remember, image > map) and not updating georeferencing until you know your links are good, based on the statistics shown for the links.
Before you start again, it probably would be good to re-read the help:
http://desktop.arcgis.com/en/arcmap/latest/manage-data/raster-and-images/fundamentals-for-georeferencing-a-raster-dataset.htm
I found this youtube video that walks you through the process, though he probably uses more control points than needed
https://www.youtube.com/watch?v=s-DERzmbIgM
