ArcMap fails to connect to SQL server machine that has real IP (domain name),
Despite the fact that the SQL server database can be access with machine domain name and SQL logins, the ArcMap fails
What could be the issue here?
Hi Jamal,
Thank you for the answer
SQL Server: 2016 both on the server and client machines
ArcMap: 10.6.1
Can you connect to the SQL instance geomolg.ps from you local SSMS install?
I see that you can access it locally from the VM that is hosting the SQL instance. I am wondering if it can be accessed remotely at all.
Thanks George.
Do you mean that the SQL Server database can’t be accessed remotely (via internet but not over the network) if its machine has real IP? Is this by design?
When I'm asking about the client, I'm referring to the additional software that is installed in order for ArcMap to connect to SQL.
https://www.microsoft.com/en-us/download/details.aspx?id=52676
Do you have this on your ArcMap machine?
https://desktop.arcgis.com/en/system-requirements/10.6/database-requirements-sqlserver.htm
SQL Server 2016
Hi Luba,
The screenshot below shows the version of SQL server database both in the server and client machine.
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
