I have the same thing going on with 10.3
I can't seem to open this link. Do you have a workaround for 10.3.0.4322?
Other times earlier this week, I would try to republish, and after I selected the Continue button on the Overwrite an Existing Service and answered "Yes" to continue, nothing would happen. I would just be returned to my MXD. Again, if I tried it over and over, it would eventually work.
I am running Desktop 10.3.0.4322. I am having this issue with overwriting a service. I have the same usual workflow of editing my MXD (adding a new file GDB feature class and publish) and previously was able to overwrite the service. Today when I answer yes to continue overwriting the same service in AGOL, the publishing window doesn't appear and I return to the MXD. The only difference in my workflow today was editing my MXD map document properties, however the publishing window did not appear even before I edited the map document properties. Bug?
Just to quickly follow up on Jarom's post, the bug in question is "NIM098200 - Unable to overwrite a hosted feature service without a service definition in My Content." The severity of the bug is currently set to Medium. Anyone with a tech support case attached to that bug who has a maintenance contact can request a bug escalation using the steps in the following blog:
Bug Escalation Process via the UAG | Support Services Blog
The feature service published still had the definition file, but would not overwrite. A new coded value had been added to the domain on one of the fields and (maybe) that was why.
Finally an answer. This behavior is occurring because the service definition (SD) file has been deleted from your ArcGIS Online account at some point in time. When you publish your hosted feature service, a SD file is automatically created. If you have this along with the hosted feature service, you should be able to overwrite your service as expected. However, if the SD file has been deleted, you will experience what is being described in this post.
This is a bug that Esri is aware of but it is not an escalated bug. There is no timeframe when it will be fixed. You should not have to keep the SD file once the hosted feature service has been published. Rule of thumb for now, keep the SD file for a hosted feature layer you know you may need to overwrite.
Having the same issue as described by , 10.2.2
Is there a reason/fix for this
I was having same problem from 10.2 and now I have upgraded it to 10.3.1 but still having same problem!!
I too am experiencing as Jarom Hlebasko, I am using ArcGIS 10.2.23.3552 for Desktop and everytimem I go to publish over an existing map service I get up to the Warnining message dialog box, click 'yes' and get booted back into my Arcmap session. Any know resolution for this?
I have the exact same issue in ArcGIS Desktop 10.2.2. The hosted feature layer in question is owned by me (Publisher), is in my root folder, and only contains a few dozen features. Setting the layer to editable or not makes no difference.
Susan Moore wrote: Other times earlier this week, I would try to republish, and after I selected the Continue button on the Overwrite an Existing Service and answered "Yes" to continue, nothing would happen. I would just be returned to my MXD. Again, if I tried it over and over, it would eventually work.
I have ArcGIS for Desktop 10.3 running and I'm experiencing exactly what is posted above by Susan. I follow the easy steps to share a service by going to File>>Share As>>Service and then select the option Overwrite an existing service in the Share as Service dialog box. I then click Next and choose the service I want to overwrite and then click Continue. A Warning Message pops up (below) asking me to continue with the overwrite so I click Yes and NOTHING HAPPENS. It boots me out to my ArcMap session. I keep trying and trying and I get nothing. Any suggestions?
DT 10.2.2
I successfully overwrote several hosted services which are not in the root folder yesterday, but today keep getting "error: code 400 item does not exist in this folder, bad syntax in request." The message then invites me to look at the server logs...
Any Esri folks out there available for comment?
Yes, I'm still having this issue as well in 10.2.2. However, if I receive the "map service is inaccessible or does not exist" error and wait before trying to access it again, it will eventually work.
I haven't been able to pin down a guaranteed "wait" time. Sometimes it works immediately, and sometimes I get frustrated, leave for lunch, come back and viola, it's working.
I had the exact same issue at 10.2.2 yesterday.
Publish hosted feature service. Make a change to the mxd, then choose overwrite an existing service. Go back to the AGOL map and "map service is inaccessible or does not exist".
I tried to replicate the problem today and it worked...
I tried creating a new service w/the same name, but it tells me the service already exists.
