Hi all, I'm kind of new to CAD and I was wondering if in ArcMap it's possible to build 3D model from a CAD file (dwg or dxf). I attach an image with the kind of data I have. The numbers on buildings and streets (annotations?) are the heights of each these features (at sea level).Does anybody know if it's possible to build a 3D model with this data? I have seen something similar done interpolating data on shapefiles but I don't know if that applies to CAD files.Thanks in advance, JF
Hello,I have a similar problem, but with point elevation data. I have used the CAD to Geodatabase tool, but the elevations are stored as text in the annotation file and not as numeric data in the point layer. Does anyone know how to assign these elevations to their corresponding points in the point layer?Thanks,Corey
