Arc Hydro tools Pro を使用しようとしていますが、DEM Reconditioning の実行に失敗します。<\/SPAN>ArcMap でも試しましたが、こちらも失敗します。<\/SPAN> <\/SPAN> <\/SPAN>ArcGIS Pro 2.2.2 と ArcMap 10.6.1 を使用しています。<\/SPAN> <\/SPAN>ご助力ありがとうございます。<\/SPAN><\/P><\/BODY><\/HTML>
Send me the data and I will see whether I can reproduce the issue.
Christine
I've had problems with DEM Reconditioning for a while and have had to create my own Model Builder Model to perform the task of burning streams and building walls.
Mark
Where can I send you the data? they are not public data. Can we open a case?
I will send you a private box link.
There is not enough space to load the files
