<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" xmlns:esri="http://www.esri.com/2008/ags" > <mx:Script> <![CDATA[ import mx.events.ItemClickEvent; import mx.collections.ArrayCollection; import mx.controls.RadioButton; private function loadLayerName():void { layerPanel.removeAllChildren(); //loop through each layer and add as a radiobutton for(var i:uint = 0; i < (dynamicLayer.layerInfos.length); i++) { var radioBtn:RadioButton = new RadioButton; radioBtn.groupName = "radioBtnGroup"; radioBtn.value = i; radioBtn.label = dynamicLayer.layerInfos.name; layerPanel.addChild(radioBtn); } //set the visible layer the first radio button radioBtnGroup.selectedValue = 0; dynamicLayer.visibleLayers = new ArrayCollection([0]); } private function radioClickHandler(event:ItemClickEvent):void { // update the visible layers to only show the layer selected dynamicLayer.visibleLayers = new ArrayCollection([event.index]); } ]]> </mx:Script> <esri:Map id="myMap"> <esri:extent> <esri:Extent xmin="-126" ymin="27" xmax="-72" ymax="50"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer" load="loadLayerName()" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/{myURL.selectedItem}/MapServer" /> </esri:Map> <mx:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0"> <mx:Array> <mx:String>Specialty/ESRI_StateCityHighway_USA</mx:String> <mx:String>Specialty/ESRI_StatesCitiesRivers_USA</mx:String> <mx:String>Demographics/ESRI_Census_USA</mx:String> </mx:Array> </mx:ComboBox> <mx:Panel id="layerPanel" width="300" height="250" x="20" y="250" paddingLeft="20"> <mx:RadioButtonGroup id="radioBtnGroup" itemClick="radioClickHandler(event)"/> </mx:Panel> </mx:Application>
Hi, Try this one out. It will add all layers automatically and make the first layer visible.<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" xmlns:esri="http://www.esri.com/2008/ags" > <mx:Script> <![CDATA[ import mx.events.ItemClickEvent; import mx.collections.ArrayCollection; import mx.controls.RadioButton; private function loadLayerName():void { layerPanel.removeAllChildren(); //loop through each layer and add as a radiobutton for(var i:uint = 0; i < (dynamicLayer.layerInfos.length); i++) { var radioBtn:RadioButton = new RadioButton; radioBtn.groupName = "radioBtnGroup"; radioBtn.value = i; radioBtn.label = dynamicLayer.layerInfos.name; layerPanel.addChild(radioBtn); } //set the visible layer the first radio button radioBtnGroup.selectedValue = 0; dynamicLayer.visibleLayers = new ArrayCollection([0]); } private function radioClickHandler(event:ItemClickEvent):void { // update the visible layers to only show the layer selected dynamicLayer.visibleLayers = new ArrayCollection([event.index]); } ]]> </mx:Script> <esri:Map id="myMap"> <esri:extent> <esri:Extent xmin="-126" ymin="27" xmax="-72" ymax="50"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer" load="loadLayerName()" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/{myURL.selectedItem}/MapServer" /> </esri:Map> <mx:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0"> <mx:Array> <mx:String>Specialty/ESRI_StateCityHighway_USA</mx:String> <mx:String>Specialty/ESRI_StatesCitiesRivers_USA</mx:String> <mx:String>Demographics/ESRI_Census_USA</mx:String> </mx:Array> </mx:ComboBox> <mx:Panel id="layerPanel" width="300" height="250" x="20" y="250" paddingLeft="20"> <mx:RadioButtonGroup id="radioBtnGroup" itemClick="radioClickHandler(event)"/> </mx:Panel> </mx:Application>
private function loadLayerName():void { layerPanel.removeAllChildren(); //loop through each layer and add as a radiobutton for(var i:uint = 0; i < (dynamicLayer.layerInfos.length); i++) { var chks:CheckBox = new CheckBox; chks.name="{checks}" chks.label= dynamicLayer.layerInfos.name; layerPanel.addChild(chks); } }
//add event listener var chks:CheckBox = new CheckBox; chks.addEventListener(Event.CHANGE, chk_changeHandler); protected function chk_changeHandler(event:Event):void { var checkBox:CheckBox = event.currentTarget as CheckBox; if (checkBox.selected = true) { trace("check is selected"); //add to visiblelayers } else { // remove from visiblelayers } }
<s:Panel> <s:layout> <s:VerticalLayout paddingTop="10" gap="2"/> </s:layout> </s:Panel>
<fx:Declarations> <s:RadioButtonGroup id="radioBtnGroup" itemClick="radioBtnGroup_itemClickHandler(event)" /> <!-- Place non-visual elements (e.g., services, value objects) here --> </fx:Declarations> <esri:Map id="myMap"> <esri:extent> <esri:Extent xmin="-126" ymin="27" xmax="-72" ymax="50"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer" load="loadLayerName()" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/{myURL.selectedItem}/MapServer" /> </esri:Map> <mx:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0"> <fx:Array> <fx:String>Specialty/ESRI_StateCityHighway_USA</fx:String> <fx:String>Specialty/ESRI_StatesCitiesRivers_USA</fx:String> <fx:String>Demographics/ESRI_Census_USA</fx:String> </fx:Array> </mx:ComboBox> <s:Panel id="layerPanel" y="250" width="300" height="250" horizontalCenter="0" > <s:layout> <s:VerticalLayout paddingTop="10" gap="2"/> </s:layout> <s:RadioButton label="Button 1" groupName="radioBtnGroup"/> <s:RadioButton label="Button 2" groupName="radioBtnGroup"/> </s:Panel>
<s:RadioButton label="Button 1" group="{radioBtnGroup}"/>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:esri="http://www.esri.com/2008/ags"> <s:layout> <s:VerticalLayout/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.events.LayerEvent; import mx.collections.ArrayCollection; import mx.events.ItemClickEvent; import spark.components.RadioButton; protected function loadLayerName(event:LayerEvent):void { layerPanel.removeAllElements() //loop through each layer and add as a radiobutton for(var i:uint = 0; i < (dynamicLayer.layerInfos.length); i++) { var radioBtn:RadioButton = new RadioButton; radioBtn.group = radioBtnGroup; radioBtn.value = i; radioBtn.label = dynamicLayer.layerInfos.name; layerPanel.addElement(radioBtn); } //set the visible layer the first radio button radioBtnGroup.selectedValue = 0; dynamicLayer.visibleLayers = new ArrayCollection([0]); } protected function radioClickHandler(event:ItemClickEvent):void { // update the visible layers to only show the layer selected dynamicLayer.visibleLayers = new ArrayCollection([event.index]); } ]]> </fx:Script> <fx:Declarations> <!-- Place non-visual elements (e.g., services, value objects) here --> <s:RadioButtonGroup id="radioBtnGroup" itemClick="radioClickHandler(event)"/> </fx:Declarations> <esri:Map id="myMap"> <esri:extent> <esri:Extent xmin="-126" ymin="27" xmax="-72" ymax="50"> <esri:SpatialReference wkid="4326"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer" load="loadLayerName(event)" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/{myURL.selectedItem}/MapServer" /> </esri:Map> <s:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0" width="300"> <s:dataProvider> <s:ArrayList> <fx:String>Specialty/ESRI_StateCityHighway_USA</fx:String> <fx:String>Specialty/ESRI_StatesCitiesRivers_USA</fx:String> <fx:String>Demographics/ESRI_Census_USA</fx:String> </s:ArrayList> </s:dataProvider> </s:ComboBox> <s:Panel id="layerPanel" width="300" height="250" x="20" y="250"> <s:layout> <s:VerticalLayout paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10"/> </s:layout> </s:Panel> </s:Application>
