Hi everyone, my name is Asaf and I am doing a GIS course, I have been trying to generate some rasters using the raster calculator but I get this error message: "error 000539: error running expression: rcexec () < type 'exceptions runtime error' > error 000732: input raster: Dataset C:/ Users......"
first, I used the raster layer "nav_dem_10m"(its an elevation raster) from the gdb file we downloaded from the course as the input to create a slope and aspect rasters using the spatial analyst tool> surface>slope/aspect.
second, I used the new slope raster to generate a raster with slopes grater than 20 degrees, using the raster calculator.
that went fine. But when I try to make a new raster showing only the westerly aspect, by using the raster calculator, I get the above error.
Here is what I type in the calculator: ("Aspect_nav_d1" > 225) & ("Aspect_nav_d1" < 315).
I get this error for other rasters I try to create with the raster calculator, for example if I try to make a raster showing only elevations around 150 meters using the mentioned above elevation raster "nav_dem_10m"
Here is the URL for this map document, it is publicly shared.
http://www.arcgis.com/home/item.html?id=0d1d560478a04bc8948a188c8c45c631
Thanks in advance, Asaf
