I know very little about the use of domNode element and interested in learning more. I had a look at the attribute inspector and could see the domNode but dont understand now it works. Any pointers would be good.
yourPopup.setContent(yourAttrInspector.domNode);
I've built an web app that is based on the following sample http://help.arcgis.com/en/webapi/javascript/arcgis/demos/ed/ed_default_editingwidget.html however my attribute table is very long and i'm not getting the look/feel that i want by playing around with the positioning and size of the infowindow. Therefore i was wondering if it was possible to modify the above sample so that instead of a infowindow you had a dialog box openup, in a fixed position/size that contained the attributes to either edit or create. Or perhaps moving the infowindow into dijit.layout.ContentPane. Is this possible? Si
