I have a program written in Visual Basic through ArcGIS 9.3 which has worked fine for a few years and now suddenly I get an error every time I try to run it. I have not updated my programs in the recent past and the programming language seems sound to me. My other programs seem to work. Can anyone look at this and help me figure out what might be causing a problem. I get Run-Time error '91' Object variable or With Block variable not set. I have posted the code below, the code I have provided is supposed to go through each layer in my .mxd until it finds one with features selected in it. I get an error on the very last line If pSelSet.Count > 0 Then Exit Do and I can't figure it out.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
