Hi Matthias,The Object Attributes info panel only shows the first 10 characters of an attribute field name. Can this be changed in the next version of CE so that the complete field names will display? This is an small but important feature since the abbreviated names are transferred to the web scene info panel and our users have been confused by the shortened field names. Also, we noticed that the field names are sorted alphabetically but in an descending order which is opposite of what we would expect to see. Thanks,Scott
Unfortunately it is the nature of shapefiles to only show 10 characters. The only way to have more than 10 characters is to use a goedatabase. As a workaround what you can do is populate the alias field with the title you want. You can even take out the underscores to make it look better.
