I notice that no one from ESRI has posted anything on this thread. I totally agree - I have several UI controls in 9.3.1 that are very important to my work. As it stands now, I won't switch to 10 until I can figure out a way around this. Sometimes I think that ESRI updates software without any input from the people who actually use it.
I just tested the autoload method of an Add-In ArcMap Application Extension. That mode causes the extension to automatically fires up at ArcMap start. ... Admittedly, this is not as easily done as creating and storing a template map, but it does provide at least one method for acheiving the same end result that is not document based.
