You'll need to provide more information, including:The RDBMS you are usingThe geometry storage formatThe topology class of the features (point/line/polygon)Note that not everyone on this forum self-identifies as a "geek", so your greeting might be considered offensive to some. I suggest you stick toless charged terms when requesting help from folks.- V
Polygons have at least 3 unique vertices and a centroid -- Which X,Y value are you trying to extract? Or do you want them all? And what are you planning to do with it/them once you have it/them?- V
It might be easier to use ST_PointN to fetch individual points inside PL/SQL(instead of text processing on a CLOB), which is why I asked what you wereplanning to do with them.- V
