I'm working with a polygon layer see image merge1. I selected all the circle polygons show then using the merge tool on the edit menu. The polygons completely loose their original shape see image merge2. I've never seen this happen before. Does anyone have any ideas how to stop this from happening.
Hi Linda,
I have a few questions:
Please let me know.
Thanks!
-Scott
1 Data is in GCS North American 1983
2. Map is also in GCS North Amercian 1983
3. The circles were made using the Crete Features Circle
After doing the merge in this area this happens...
the blue hatched area is what was created after this merge, the green circles are a copy of the original data.
Note I'm using ArcGIS Pro 2.3
I created similar data in GCS North American 1983 in a Map that is also in GCS North American 1983. I then used the Merge tool (Edit tab), but I'm not reproducing the issue in 2.3 or 2.4. It seems that this could happen if the data was being projected on the fly based on my testing. Can you please send a screenshot of the following:
Map properties > Coordinate Systems section > Expand layers > Expand the current coordinate system to show all layers. I'm assuming the layer name will show up there "WCA_WTF"
Please let me know, thank you!
Yes the layer is WCA_WTF
From the screenshot, I can tell your map is not in GCS North American 1983. It's in WGS 1984 Web Mercator Auxiliary Sphere. Please try setting the Map's coordinate system to match the data you are editing - GCS North American 1983.
Specify a coordinate system—Properties of maps | ArcGIS Desktop
