I just installed the latest update for the Ops Dashboard. I am now no longer able to see it in a browser. If this is an unkown issue, I wanted to make it known. Thanks and cheers!
Hi Ed,
Could you provide more details about your issue. What is the message you are seeing when you say " I am now no longer able to see it in a browser" ? How are you opening your dashboard in the browser? From a shared link or from the items details link from AGOL? If you have mixed content in your op view sometimes the browser will block it from launching the app. If the link in the browser says https:// .... try removing the (s). More detail about your issue would be great to narrow down the problem.
Thanks
Carol
Hi Carol,
Thanks for your fast reply and please accept my apologies for my slow one. It doesn't matter what device, browser, or method that I use to load the dashboard (hyperlink or the "Open in" option in AGOL), it simply fails to load. I have no https and all 4 feature services are hosted in my AGOL organzation's account. I have messed around with one of the editable feature services several times, I'm thinking about going back and creating it from scratch to see if that helps. Thanks again for your reply. Cheers!
Not a problem Ed. I would suggest you try to isolate the issue by adding one layer at a time in your op view and see if it loads. You may have already done so?
-Carol
I haven't done that and haven't thought about doing that. Thanks!
I Just tried again after the newest update. It now works beautifully in a browser.
