Hi Jamal,That error can mean a few things including that you don't have write permissions to the the Apps folder (C:\inetpub\wwwroot\Apps) or that the name of the App already exists.Hope that helps,Katy
This is typically a security issue on a server. Restricted permission to example the inetpub\wwwroot folderNever a good idea to give unrestricted access to these foldersBetter alternative is to deploy on a desktop/laptop and to copy application over to the server using the appropriate permissionsAlternatively, use a folder other than in wwwroot and share it in IIS
