Is it possible to remove part of the url I want to use to show photos in a popup through the ArcGIS Online image configuration console? I found a link that made me think this might be possible here: Show attached images inside popup with ArcGIS Online? - Geographic Information Systems Stack Exchange. Any suggestions?
Brandon
https://community.esri.com/community/gis/web-gis/web-appbuilder?sr=search&searchId=632f7fb4-464e-4241-b6e3-c5b532863535&searchIndex=2
@arcgis
Not sure what you mean with remove part of the URL. Can you give an example?
There is a tool that might be interesting to look at: https://community.esri.com/docs/DOC-7445
I am using someone else's layer in my webmap: http://www.dot.ca.gov/hq/env/gis/stormwater/sdsi/d7/photos/dp/110_s_22_12966_dis_34_0358_118_2749/index.html
if I remove the last 10 characters so it reads: http://www.dot.ca.gov/hq/env/gis/stormwater/sdsi/d7/photos/dp/110_s_22_12966_dis_34_0358_118_2749/.
Then I can add 1.jpg so its reads: http://www.dot.ca.gov/hq/env/gis/stormwater/sdsi/d7/photos/dp/110_s_22_12966_dis_34_0358_118_2749/1.jpg
I wanted to do this using a script within the configure pop/add photo section of arcgis online if possible. I have seen this done before as I stated earlier in this thread: Show attached images inside popup with ArcGIS Online? - Geographic Information Systems Stack Exchange (What is the programming language in this thread? Javascript?)
I have several layers like this and this wouldn't be practical to download everyone and make the field changes in arcmap
This is great. This works just. Only for https it seems.
works just fine*
Sorry. Wrong thread.
Can you revise your comments?
Can you share the URL to the service you're using to have a look what can be achieved?
