Check out our blog post we just posted going over this 10.3 release here:
Collector for ArcGIS v10.3 is out and it’s a big deal!! | ArcGIS Blog
Key Features:
*Currently Android is out in the Google Play Store now. iOS is making its way through the App Store and will be out soon.
Cheers
Russ
When will this release be available within the App store? I see that it is available within Google Play as of this post.
Thanks!
Mike
Yup this release will be coming to iOS. We are currently going through the approval process and should be coming very soon.
Great! Thanks for the update as I am currently installing the new version on my Droid.
Russell, Has there been any documentation on enabling the ability to edit related tables within the collector app?
I would be keen to see documentation, too. I am planning to use this feature and am ready to start preparing my dataset. I could start this immediately, while I wait for the iOS version to update.
G'day Russ!
Is there also a fine grained list of all the changes made?
Thanks
Hi Russell! Good to see the updates regarding the different editing rights carrying across to the offline versions. However, has the Copy shape feature been removed or relocated? We can't find it anymore.
It looks like whatever determines if the "copy" option appears has been changed, unfortunately this breaks things for us in big way. Is copying now restricted to layers that are editable? Can this be changed!?
Here is a list of enhancements and fixes under the What's New: Collector for ArcGIS | ArcGIS
Hey Pete, We've identified an issue with certain layer configurations not showing copy and are looking into it.
Thanks Russ, looking forward to trying out the new stuff.
I've played around with the layer settings a bit and have found that the following combination seems to allow Copying of features in that layer, whilst limiting edits to only the person who's created it.
If the Editing settings are on Add or Update only, you won't be able to copy those features. You also need to Enable Editing of the Layer through the Layer options in your map. If this is set to Disable Editing it will remove the Copy option again.
The Android app has been updated to fix the copy issue.
I still do not see the latest edition at App Store.
I only see 10.2.7.
ESRI states that it will be released after it finishes the Apple App store review. Rumor of this week into next week.
I have to say that I am extremely pleased with the recent update that supports related tables on android, but I'm patiently awaiting the iOS version also.
The iOS version of Collector 10.3 is now live in the App Store
