you can try the custom relation *T******* -
I know that there have been issues with data in file geodatabases where the Geo on Geo check returns features that are connected. If the data is in a personal gdb, the results are okay. I've also applied a small tolerance, like 6", when working with file geodatabases to get correct results.Ted, This is the geometry on geometry check using the Spatial Relationship "Relation". When this is selected it will enable the Custom Spatial Relation text box.
I'm having issues with the Geometry on Geometry Check. I'm looking for point features that do not intersect a line feature. The reviewer is flagging orphan points but is also flagging points snapped to the end of only one line. Points snapped to the end of more than one line are fine. I have tried multiple Spatial Relation Check types. Any advice?Reviewer 9.3.1 SP1 Patch2 build 533
