geometryService.project([mapPoint], outSR);
var mapPoint:MapPoint = map.toMapFromStage(event.stageX, event.stageY); var outSR:SpatialReference = new SpatialReference(4326); geometryService.project([mapPoint], outSR);
var geom:Geometry = (event.result as Array)[0]; var mapPoint:MapPoint = geom as MapPoint; var lng:String = mapPoint.x.toFixed(12); var lat:String = mapPoint.y.toFixed(12); // launch street view etc etc
private function projectCompleteHandler(event:GeometryServiceEvent):void { var mapPoint:MapPoint = (event.result as Array)[0]as MapPoint; var lng:String = mapPoint.x.toFixed(3); var lat:String = mapPoint.y.toFixed(3); // launch street view var url:String = "http://gis.kilkennycoco.ie/flex/streetview/index.html?lat=" + lat + "&lng=" + lng; var window:String = "_blank"; var features:String = "toolbar=no,location=no,resizable=no,directories=no,status=no,scrollbars=no,copyhistory=no,width=600,height=400"; var WINDOW_OPEN_FUNCTION : String = "window.open"; ExternalInterface.call( WINDOW_OPEN_FUNCTION, url, window, features ); CursorManager.removeAllCursors(); }
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mxeffects="com.adobe.ac.mxeffects.*" layout="absolute" creationComplete="addStatList()"> <fx:Declarations> <esri:GeometryService id="geometryService" concurrency="last" fault="onFault(event)" projectComplete="projectCompleteHandler(event)" url="http://gis.calhouncounty.org/arcgis2/rest/services/Geometry/GeometryServer"/> <esri:SimpleMarkerSymbol id="smsPoint" style="square" color="0xFFFF00" size="11" alpha="0.9"> <esri:SimpleLineSymbol color="0x000000"/> </esri:SimpleMarkerSymbol> </fx:Declarations> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.GeometryServiceEvent; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.viewer.AppEvent; import com.esri.viewer.ViewerContainer; import mx.controls.Alert; import mx.managers.CursorManager; [Embed(source="assets/images/gsv_cursor.png")] private var crosshairCursor:Class; private var theStatus:String = ""; public function google():void{ setMapAction("","Show Google Street View",null); map.addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler); map.panEnabled = false; map.cursorManager.setCursor(crosshairCursor, 2, -8, -12); } private function mouseDownHandler (event:MouseEvent):void { if(theStatus == "Show Google Street View") { map.cursorManager.setBusyCursor(); var mapPoint:MapPoint = map.toMapFromStage(event.stageX, event.stageY); var outSR:SpatialReference = new SpatialReference(4326); geometryService.project([mapPoint], outSR); } else { map.removeEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler); } } private function widgetClosedHandler(event:Event):void { map.removeEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler); map.panEnabled = true; map.cursorManager.removeCursor(map.cursorManager.currentCursorID); setMapNavigation(null, null); } private function widgetOpenedHandler(event:Event):void { google(); } private function addStatList():void { ViewerContainer.addEventListener(AppEvent.SET_STATUS, statusSet); theStatus = "Show Google Street View"; } private function statusSet(event:AppEvent):void { if (event.data) theStatus = event.data as String; } private function projectCompleteHandler(event:GeometryServiceEvent):void { var geom:Geometry = (event.result as Array)[0]; var mapPoint:MapPoint = geom as MapPoint; var lng:String = mapPoint.x.toFixed(12); var lat:String = mapPoint.y.toFixed(12); // launch street view var url:String = "http://gis.calhouncounty.org/FlexViewer2.0/StreetView.html?lat=" + lat + "&lng=" + lng; var window:String = "StreetView"; var features:String = "toolbar=no,location=no,resizable=no,directories=no,status=no,scrollbars=no,copyhistory=no,width=610,height=700"; var WINDOW_OPEN_FUNCTION : String = "window.open"; ExternalInterface.call( WINDOW_OPEN_FUNCTION, url, window, features ); } private function onFault(info:Object, token:Object = null):void { Alert.show(info.toString(),"Streetview Error"); } protected function button1_clickHandler(event:MouseEvent):void { ViewerContainer.showError("This is a test error"); } ]]> </fx:Script> <viewer:WidgetTemplate id="wTemplate" closed="widgetClosedHandler(event)" open="widgetOpenedHandler(event)" creationComplete="google()" skinClass="com.esri.viewer.skins.WidgetTemplateSkin" height="280" width="370"> <mx:VBox width="100%" height="100%" verticalGap="4" horizontalAlign="center" verticalAlign="middle" > <mx:HBox width="100%" horizontalGap="15" horizontalAlign="center" verticalAlign="middle"> <mx:Text id="selectPointLabelText" text="Click location on the map to open Google® streetview panorama" styleName="WidgetText" width="90%" textAlign="center"/> </mx:HBox> <mx:Button click="google()" label="Reactivate..."/> </mx:VBox> </viewer:WidgetTemplate> </viewer:BaseWidget>
private function widgetClosedHandler(event:Event):void { map.removeEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler); map.panEnabled = true; map.cursorManager.removeCursor(map.cursorManager.currentCursorID); setMapNavigation(null, null); map.cursorManager.removeCursor(map.cursorManager.currentCursorID); }
