import arcpy, os from arcpy import env env.overwriteOutput = True # Get arguments: # Input point feature class # Output polygon feature class # Buffer distance # Boolean type: Maintain fields and field values of the input in the output print "initializing" inPoints = "C://YourDataDirectory//yourPoint.shp" outPath = "C://YourDataDirectory" outName = "SqBuffer" bufDist = 15000 #in meters outPolys = outPath+"//"+outName+".shp" print "creating new blank feature" arcpy.CreateFeatureclass_management(outPath, outName,"POLYGON","","","", "", "","","","") print "created" # Open searchcursor inRows = arcpy.SearchCursor(inPoints) # Open insertcursor outRows = arcpy.InsertCursor(outPolys) # Create point and array objects pntObj = arcpy.Point() arrayObj = arcpy.Array() print "writing geomety" for inRow in inRows: # One output feature for each input point feature inShape = inRow.shape pnt = inShape.getPart(0) # Need 5 vertices for square buffer: upper right, upper left, lower left, # lower right, upper right. Add and subtract distance from coordinates of # input point as appropriate. for vertex in [0,1,2,3,4]: pntObj.ID = vertex if vertex in [0,3,4]: pntObj.X = pnt.X + bufDist else: pntObj.X = pnt.X - bufDist if vertex in [0,1,5]: pntObj.Y = pnt.Y + bufDist else: pntObj.Y = pnt.Y - bufDist arrayObj.add(pntObj) # Create new row for output feature feat = outRows.newRow() # Assign array of points to output feature feat.shape = arrayObj # Insert the feature outRows.insertRow(feat) # Clear array of points arrayObj.removeAll() # Delete inputcursor del outRows print "done
This works for me... just a simple python script...import arcpy, os from arcpy import env env.overwriteOutput = True # Get arguments: # Input point feature class # Output polygon feature class # Buffer distance # Boolean type: Maintain fields and field values of the input in the output print "initializing" inPoints = "C://YourDataDirectory//yourPoint.shp" outPath = "C://YourDataDirectory" outName = "SqBuffer" bufDist = 15000 #in meters outPolys = outPath+"//"+outName+".shp" print "creating new blank feature" arcpy.CreateFeatureclass_management(outPath, outName,"POLYGON","","","", "", "","","","") print "created" # Open searchcursor inRows = arcpy.SearchCursor(inPoints) # Open insertcursor outRows = arcpy.InsertCursor(outPolys) # Create point and array objects pntObj = arcpy.Point() arrayObj = arcpy.Array() print "writing geomety" for inRow in inRows: # One output feature for each input point feature inShape = inRow.shape pnt = inShape.getPart(0) # Need 5 vertices for square buffer: upper right, upper left, lower left, # lower right, upper right. Add and subtract distance from coordinates of # input point as appropriate. for vertex in [0,1,2,3,4]: pntObj.ID = vertex if vertex in [0,3,4]: pntObj.X = pnt.X + bufDist else: pntObj.X = pnt.X - bufDist if vertex in [0,1,5]: pntObj.Y = pnt.Y + bufDist else: pntObj.Y = pnt.Y - bufDist arrayObj.add(pntObj) # Create new row for output feature feat = outRows.newRow() # Assign array of points to output feature feat.shape = arrayObj # Insert the feature outRows.insertRow(feat) # Clear array of points arrayObj.removeAll() # Delete inputcursor del outRows print "done Is this what you are looking for?
Hi there, I just ran this script and it worked great for what I required; However, it wasn't perfect. I did get square buffers around the coordinates I supplied but the buffer distance wasn't accurate. I entered "375" for bufDist to create a 750m x 750m rectangle but the output created a 739m x 739m rectangle instead. An equal difference of 10.5m in each direction.Do you have any suggestions as to what happened??Thanks!p.s. the script is fantastic, I just don't understand Python all that well to troubleshoot!
