import numpy as np a = np.array([1,0,0]) b = np.array([0,1,0]) print np.cross(a,b)
# LeftRight.py # Vector Cross Product # to find which side a point is of a polyline # Kim Ollivier 18 Feb 2012 import numpy as np # Get the points from original point, Near and shape.lastPoint # eg xPnt = (1,20) intPnt = (11,9) lastPnt = (5,20) # make two 3D vectors relative to the intersection point # for a local origin at the intersection point a = np.array([xPnt[0]-intPnt[0],xPnt[1]-intPnt[1],0]) b = np.array([lastPnt[0]-intPnt[0],lastPnt[1]-intPnt[1],0]) c = np.cross(a,b) if c[2] > 0: print "Side is left" else: print "Side is right" print c
I just want to compliment Richards answer. When a python script is run from within ArcGIS as a scripting tool it's possible to call arcobjects within the calculate field tool. I've used this approach sometimes when I wanted to access the fine grade geometry tools that ArcObjects has. The QueryPointAndDistance method on IPolyline is certainly a very useful bit of wizardry I use it regularly!
