As I understood we do not need to store rasters in SQL DB and should use filebase system. But would we have any troubles with multiple access from web if for example 10 or 20 people would request same image mosaic? I have heard about some file system locks or something like it.
Also how to manage in filebase db attributes? Can I do select and insert operation from script/ written from scratch app without running ArcGIS. The problem that I can't image how to work with filebase system.
Yes. We have ArcGIS For Server for workgroup, but we need to create raster mosaic with thousand of rasters. The limitation of SQLExpress is 10GB.
Yes. We have ArcGIS For Server for workgroup, but we need to create raster mosaic with thousand of rasters. The limitation of SQLExpress is 10GB. End I have got next questions:1. Do license allow us to unde SQL Standard instead of SQLExpress? There is no problem with limits of connection and available cores. We just need bigger DB2. If license do not allow to use it, is there any restriction, that would lock ability to connect with SQL Standard? We want to test it at first, and only then think about can we buy it or no.
I know that ArcGIS for Server for workgroup can work only with MSSQL Express. But is it's possible co connect with full version of MSSQL? I need to test how it would work with big DB.
