using ESRI.ArcGIS.Editor; using ESRI.ArcGIS.Framework; using ESRI.ArcGIS.esriSystem; namespace RestartSketch { /// <summary> /// Editor Extension to add a context menu item /// </summary> public class RSExt : ESRI.ArcGIS.Desktop.AddIns.Extension { private IEditEvents_Event m_editEvents; public RSExt() { } protected override void OnStartup() { m_editEvents = ArcMap.Editor as IEditEvents_Event; m_editEvents.OnStartEditing += new IEditEvents_OnStartEditingEventHandler(m_editEvents_OnStartEditing); } void m_editEvents_OnStartEditing() { //Add to various sketch context menus by guid and bottom up position //AddtoContextMenu("{02D578D0-42AB-11d2-84D6-0000F875B9C6}", 3); //straight constructor context menu //AddtoContextMenu("{066022E8-A0FD-48e5-AF5D-F5C77E88DD42}", 3); //trace constructor //AddtoContextMenu("{68A337DF-751B-45dd-AA39-91194BE88D7C}", 3); //other constructors AddtoContextMenu("{FD799450-472C-11d2-84D8-0000F875B9C6}", 3); //over a sketch } private void AddtoContextMenu(string cmg, int pos) { // Get the context menu UID contextMenuUID = new UIDClass(); contextMenuUID.Value = cmg; ICommandBar contextMenu = ArcMap.Application.Document.CommandBars.Find(contextMenuUID) as ICommandBar; if (contextMenu != null) { // Get the command item you want to add UID commandUID = new UIDClass(); commandUID.Value = "ESRI_RestartSketch_RestartSketchCmd"; //Check if it is already present on the context menu... ICommandItem myCmdItem = contextMenu.Find(commandUID); if (myCmdItem == null) { myCmdItem = contextMenu.Add(commandUID, contextMenu.Count - pos); //myCmdItem.Group = true; myCmdItem.Refresh(); } } } } }
protected override void OnStartup() { WireEvents(); } private void WireEvents() { ArcMap.Events.OpenDocument += new ESRI.ArcGIS.ArcMapUI.IDocumentEvents_OpenDocumentEventHandler(Events_OpenDocument); ArcMap.Events.NewDocument += new ESRI.ArcGIS.ArcMapUI.IDocumentEvents_NewDocumentEventHandler(Events_NewDocument); } void Events_OpenDocument() { System.Diagnostics.Debug.WriteLine("**** Events_OpenDocument ****"); LoadContextMenu(); } void Events_NewDocument() { System.Diagnostics.Debug.WriteLine("**** Events_NewDocument ****"); LoadContextMenu(); } private void LoadContextMenu() { ICommandBars cmdBars = ArcMap.Application.Document.CommandBars; UID contextMenuUID = new UIDClass(); contextMenuUID.Value = "{BF643199-9062-11D2-AE71-080009EC732A}"; //esriArcMapUI.FeatureLayerContextMenu ICommandBar contextMenu = cmdBars.Find(contextMenuUID, false, true) as ICommandBar; if (contextMenu != null) { // Get the command item you want to add UID commandUID = new UIDClass(); commandUID.Value = "Test_TestParaTextButton"; // Add-in button ID //Check if it is already present on the context menu. ICommandItem myCmdItem = contextMenu.Find(commandUID, false); if (myCmdItem == null) { Object pos = contextMenu.Count - 1; myCmdItem = contextMenu.Add(commandUID, ref pos); //myCmdItem.Group = true; myCmdItem.Refresh(); } } else { System.Diagnostics.Debug.WriteLine("**** contextMenu is null ****"); } }
Imports ESRI.ArcGIS.ArcMapUI Imports ESRI.ArcGIS.Framework Public Class CycleThrough Inherits ESRI.ArcGIS.Desktop.AddIns.Extension Public Sub New() End Sub Protected Overrides Sub OnStartup() WireEvents() End Sub Protected Overrides Sub OnShutdown() End Sub Private Sub WireEvents() Dim docEvents As IDocumentEvents_Event Dim mapStatusEvents As IApplicationStatusEvents_Event docEvents = TryCast(My.ArcMap.Application.Document, IDocumentEvents_Event) AddHandler docEvents.NewDocument, AddressOf OnNewDocument AddHandler docEvents.OpenDocument, AddressOf OnOpenDocument If TypeOf My.ArcMap.Application.Document.Parent Is IMxApplication Then mapStatusEvents = TryCast(My.ArcMap.Application.Document.Parent, IApplicationStatusEvents_Event) AddHandler mapStatusEvents.Initialized, AddressOf OnInitialized End If End Sub Private Sub OnNewDocument() SetupContext() End Sub Private Sub OnOpenDocument() SetupContext() End Sub Private Sub OnInitialized() SetupContext() End Sub Private Sub SetupContext() Dim contextMenuGUID As New UID contextMenuGUID.Value = "{BF643199-9062-11D2-AE71-080009EC732A}" Dim myContextMenu As ICommandBar = My.ArcMap.Application.Document.CommandBars.Find(contextMenuGUID, False, False) If myContextMenu IsNot Nothing Then Dim commandGUID As New UID commandGUID.Value = "LayerCycle_CycleButton" Dim myCommandItem As ICommandItem = myContextMenu.Find(commandGUID) If myCommandItem Is Nothing Then myCommandItem = myContextMenu.Add(commandGUID, 9) 'the 9 is where I happen to want the button to be, it could be nothing or any other value myCommandItem.Refresh() End If End If End Sub End Class
