I have been using select/identify on a graphics layer that I fill at run-time. I populate grids and change the symbols as well. I can click the graphic on screen and highlight the row in the datagrid. I can click the row in the datagrid and highlight the graphic on screen. All this without having a Feature Service.Let me know if this is your case, so I can share the code.Hugo.
Can you share the code
