How many parcels do you have in your parcel fabric?I have found that recalculating indexes on the parcels, lines, points and linepoints tables after migration really helps with speeding things up.To recalculate indexes on the parcel fabric feature classes, right-click the fabric in ArcCatalog or the Catalog window and click Properties to open up the Parcel Fabric Properties dialog box. Click the Fabric Classes tab and select the feature class in the drop-down for which you want to recalculate indexes and click properties.Click Recalculate to recalculate the indexes for the fabric feature class.Christine
Darn those ideas didn't work either. How I wish it was an easy solution! Oh well I have time to work on it again today. I think I'll just focus on cleaning up Fabric Errors from the original import. Who knows if I get lucky maybe once they are all cleaned out I'll see an increase in speed.Thanks for trying though Mark. I have found MXD's causing problems in the past it would have been nice if it was the same for this problem.
