aspect.after(this.map, "onLayerAddResult", lang.hitch(this, function (layer, error) { }));
Can any ESRI staff answer the question? In what scope the JS API is compatible with dojo/on? Does ESRI have a timeline to fully support dojo/on and other dojo 1.8 features? It is annoying to mix using dojo.connect and dojo/on in the same application.
Derek, may I ask the reason for the recommendation to use object.on instead of on(object, ..)? Is that because object.on will register the event handler at the object scope, while on(object, ...) will register at the global level?
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
