Looks like the map uses a feature service that I don't have access to.
We have same issue... Summary widget displays counts perfect on desktop operations dashboard but says 'No Data' when viewed through browser.
Could you share the map with a group and invite kylie_org to that group? This issue was resolved in a previous released of the web version of Operations Dashboard (sorry for not chiming in again over here and wrapping it up!)
I do not have administrative privileges to invite you to join a group...
We have a web map using services on our server... the web map is shared with the organization....
Do the services have to be added to AGOL contetnt within the web map & have their own share settings within the organization?
No, you won't have to add all your services as AGOL items.
I don't have access to content that is just shared with your organization. If you can create a public repo case, I'd be happy to take a look (just post a link to the map). Otherwise, you'll probably have to work with support to figure out what is going on.
On the left is the widget shown within the Desktop Operations Dashboard
On the right is the widget displayed within the Browser
'No Data' within the web version of the dashboard even though item is shared within organization I am apart of...
Sorry if I wasn't clear. I believe what you are seeing, but to figure out why we'd have to be able to see the same thing. We'd need to see the data that is being used, as well as the operation view.
Hi Alexander Baker! Are there any updates in your end? I'm currently having the same problem with the browser version of Ops Dashboard.
Karen
We are seeing the exact same issue with the Operational Dashboard browser viewer hosted on our Portal. The same service will work with a bar chart but not with a summary or gauge widget. Strange stuff. Would love to get some insight into this.
Hi Chris,
The data source of my summary widget that displays "No Data" message is an Oracle View table (Oracle 11g) that I published in one of my on-premise map services. I added the service URL of view table as an external data source in Operations Dashboard to be able to use it in the Summary widget. Unfortunately, you will not be able to access my on-premise map services. So, as an alternatively I attached here the screen shots of the widgets panel my Operation Views both in Windows and Browser versions.
The photo on the right is OpDashboard-browser version while the photo on the left is the Windows version of the OpDashboard. I think it is important to take note that the two widgets (Summary and Bar) have the same data source (Oracle View Table) and the bar widget works fine in both versions of OpDashboard.
(Browser Version) (Windows Version)
Hi Karen,
Your issue (maybe different from Ryan's) is BUG-000088087 - The count value in the Summary widget in Operation..
We're currently looking in to this issue. The fault could be tied to the Object ID field, which we're investigating. If you look at your table layer in REST, does it have the ESRI_OID as it's Object ID field?
Hi Christopher,
I apologize for the late response.
My Oracle table has an ID field. When we publish the table, the ID is being read as ObjectID in my REST directory as shown in the picture below:
Thank you for taking time looking at this issue. One of our clients is planning use the browser version of the OpsDashboard using the same set-up from my previous post so this concern is really critical to us. Hoping for a positive response soon.
Regards,
OK, yours might be a different issue then. The screenshot tells a lot- your OBJECTID field is just a name, not a true OID field since it's an integer field. A true object ID field is maintained by the database and has a specific field type:
This could be the problem and can cause widgets to fail. Can you try with another layer/table that has this field with the summary widget and let me know?
i am having the same issue with the online dashboard. All the figures are wrong and do not correspond with the attribute table. Was there ever a fix for this?
