anyone get this message when using collector to access Portal?
Hi Scott
can you provide more detail. At what point is collector timing out. When you open, load a map or enter a point etc...?
Thanks
when i attempt to sign in. Collector successfully validates I have the correct web address for Portal, then I sign in and it times out. I have used mutliple logins all with the same result 'The request timed out'
Thanks for responding
Scott,
are you a member of the Collector Pilot Group?
If not check with GIS Support.
Regards
No I am not….
Hi Jürgen Achilles ... I think you have your groups mixed up
Hi Scott Ballard
Can you connect to the Portal via a web browser?
yes i can
