I had the same issue. When I contacted ESRI Support, they told me how to fix it:Start button > Run > regeditDrill down to HKEY_CURRENT_USER > Software > ESRI > Desktop10.0 > RasterRename the folder from Raster to OldRasterIt worked for me. Good luck!
As expected this issue returned after I installed the Desktop part of the ArcGIS 10 (Desktop, Engine, Server) Raster Format patch from http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=17&MetaID=1648I left ArcMap 10 open while editing the registry but had to then close and re-open ArcMap before seeing the workaround take effect.Anyone know an NIM bug number for this that we can use to track when it is fixed?- Graeme
Hi EricNIM060238 looks like it has missed the ArcGIS 10 SP1 list of issues fixed at http://downloads2.esri.com/support/documentation/ao_/10.0_SP1_Announcement.pdf - is there any chance that it can be included, please?- Graeme
The ID to track the ECW issue is here.NIM060238: ECW is temporarily shown as invalid dataset.Please note, the Raster Format Patch recently released was not meant to resolve this issue. To see the issues resolved by the patch, read the section, "Issues Addressed with this Patch".http://resources.arcgis.com/content/...17&MetaID=1648The ECW bug has been given high priority by the User Advocacy Group and we continue to work with Development to get the issue resolved as quickly as possible.Regards,Eric
Yes, I just upgraded to ArcGIS 10 and installed the service pack and my image service will not start now with our .ecw aerial. You can't even pick it when you create a new service as I could in 9.3.
ESRI indicates that you must contact ERDAS to obtain a license to use with ArcGIS Server. I thought this would be like obtaining a license from UNISYS to use .gif (which is not public domain) but no - the charge is $3600 for an 8 core server. We will be using a different format from this point forward - particularly since our imagery ends up as a cache anyway.
