Hi folks,
we would like to display thousands of graphics in our GraphicsLayer and cluster them according to a particular zoom level. There used to be a GraphicsClusterer (ArcGIS API for WPF) in former SDK. How do we solve this problem with the newer SDK?
Kind Regards,
Eugen
📢 Displaying point feature layer enabled with clustering, published via ArcGIS Pro or ArcGIS Online is now supported in latest version of ArcGIS Maps SDK for .NET version 200.2.
Check out Release Notes to find out what's new and a public sample demonstrating displaying point layer using feature clustering.
Note this question relates to the forthcoming ArcGIS Runtime SDK for .NET rather than the existing ArcGIS Runtime SDK for WPF.
As discussed in the beta forum (ArcGIS Runtime SDK 10.2.3 for .NET) clustering is not currently available in the beta ArcGIS Runtime SDK for .NET but is on the roadmap for a future release (beyond the initial release later this summer).
Cheers
Mike
Is there any updates regarding Clustering in 10.2.4 release of ArcGIS Runtime for .NET SDK ?
Rami.
One year later. Now version 10.2.6 is out and we are still waiting. Is their any plan for clustering in 10.2.7 ??
Still nothin new on this subject ? I really would like to update !
I do recall hearing something about updated Clustering functionality at the recent Dev Summit.
Was that only referring to Quartz?
We demo'd a sample at the Dev Summit last week which shows basic clustering functionality and can be implemented today using 10.2.7. Improved support for clustering is still on the roadmap for the Quartz release. But the sample may be enough for you to work with right now - it should perform adequately for 10s of thousands of graphics, but you should be cautious if you have 100s of thousands of graphics.
We're just wrapping up those demos and will post them on ArcGIS.com within the next couple of days.
Hi everyone,
As previously mentioned, we're working on proper support for clustering in the ArcGIS Runtime core... but in the meantime, we've included a clustering sample in our Dev Summit 2016 Tips and Tricks session - available here: http://www.arcgis.com/home/item.html?id=71e82397445a47629e45f15161ca4761.
Just remember, it should be good for 10s of thousands graphics, but exercise caution beyond that.
Any update on this? Or if it might be available in .net v100.1? I'd love to have this available in a Xamarin android project.
This is still on the roadmap for a future release. It was not in v100.1 and unfortunately we were not able to include it in the upcoming 100.2 release (late 2017 / early 2018).
In the meantime, if your data volumes are fairly low (100s-1000s of features/graphics) you could investigate porting the clustering sample above from the 10.2.X API to the 100.X API.
Hi Mike,
As you suggested I am trying to Port the above code from Esri.ArcGISRuntime 10.2.7.0 to Esri.ArcGISRuntime 100.1.0.0 (WPF). I did not get the alternative for GraphicCollection.
GraphicCollection is An observable collection of Esri.ArcGISRuntime.Layers.Graphic. in Esri.ArcGISRuntime 10.2.7.0. GraphicCollection in Esri.ArcGISRuntime 100.1.0.0.is An observable collection of Esri.ArcGISRuntime.UI.Graphic.
I tried with GraphicsOverlayCollection. But didnt work as expected.
Can you please help me out ?
Thanks in advance !!
Are there any updates on when this will be available in the 100.x version?
We also need a solution for clustering - we're currently on 100.9
Thanks for your feedback. This feature is still under consideration for a future release.
It will help our design process if you can share any additional information about what type of data you would like to cluster, how many features/graphics, what type of symbols or renderer, how you would like them to display when clustered, what level of control you would like over the clustering behavior, whether the clustering should be animated or not?
Thanks
The application that me and my team are working on requires the clustering feature because we need to display a large amount of graphics on the map 20k and more, and the clustering is a must because many of these graphics will be next to each other.
is there any estimation for the release of the clustering feature?
Thanks.
Hi @MichaelBranscomb, just wanted to check if clustering feature is now available or if there's a timeline on when it will be available. Thanks.
Thanks for your question. Clustering / feature reduction is still on the roadmap for a future release.
Hello
I am developing an application in wpf and we also have the need for clustering. ¿Is there any news about it?
All the best
FYI,
Support for displaying clusters for point feature layers in dynamic rendering mode is now supported in latest version of ArcGIS Maps SDK for .NET version 200.2 For more info please review the latest release notes.
Also refer to public sample available on pubic samples repo here.
Preeti
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
