Ugh. "Application has been blocked from accessing Graphics Hardware" .. blocking ArcGIS Pro .. anyone else have same issue and know a fix for this? Thanks all!! 🙂
Yes... just can't put my finger on the thread.
Solutions...
Of course you might want to elaborate on what you were doing that led to this
Another user was experiencing this same issue and resolved it using the following steps - "Went into the Displays option with ArcGIS Pro and deleted the cache, changed Antialiasing mode to Best, Stereoscopic mode to off and checked the Enable hardware antialiasing option."
Hope this helps!
And to follow up with Robert's suggestion
How caching works—ArcGIS Pro | ArcGIS Desktop
I never cache, but I have no need to
More than a year ago I encountered a similar problem and had to uninstall my display driver and then reinstall the driver from manufacturer. If you google this error message there are many suggestions on how to go about fixing it, I followed some of these and I ended up running a 3rd party app to uninstall display driver.
