Generate geodatabase task only downloads the first feature class using this example:
https://github.com/Esri/arcgis-runtime-samples-qt/blob/master/ArcGISRuntimeSDKQt_QMLSamples/Features/GenerateGeodatabase/GenerateGeodatabase.qml
is this expected behavior?
Thank you,
I'm not seeing this behavior. Which version are you using? Are you in an area that only has the one layer visible in it? Here is my output which contains points, lines, and polygons:
Hey Lucas,
I am downloading the whole California and the Geodatabase only has points:
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
