version of ArcMap?
Have you physically navigated to the output folder to see if there is any output?
Other possibilities of none of those apply...do all records contain valid numeric values?
When using shapefiles, keep in mind that they cannot store null values. Tools or other procedures that create shapefiles from non-shapefile inputs may store or interpret null values as zero. This can lead to unexpected results. See also Geoprocessing considerations for shapefile output.
