When resizing the widget, the datgrid would not resize properly. This has been fixed.
I am running version 2.3.1 of the viewer, ArcGIS Server 9.3.1, and an SDE database model. There are no joins on any of the layers. Again, version 1.0 worked fine.
This looks great. I'm definitely looking forward to trying it out. Will it work with SFV 2.3.1?
Hi Francesco,It is not set up to work with relationships.It works with data that has a join set in ArcGIS.
Thanks Mark,I'll try and modify the querytask to pull our data.Curtis
How do you manually recompile the older version to work in 2.4? I downloaded a trial of Adobe Flash Builder, and have no problem doing it myself. I just have no idea where to start...
Attached is the compiled version that works with flexviewer 2.4.I tested it and it works, but use it at your own risk and I assume no responsibility for anything.
<layer> <name>AMR Meter Class</name> <url>http://ags2.cdm.com/arcgis/rest/services/Arlington/MapServer/0</url> <fields> <field name="UTMTR"/> </fields> <titlefield>UTMTR</titlefield> <linkfield></linkfield> <infowindowfields> <field name="UTMTR"/> </infowindowfields> </layer>
Fantastic functionality added to FSV. Thanks for sharing this great tool.Is there anyway to have date values in the unique values box formated as dates, rather than the numbers that are actually stored?For example :<format dateformat="shortDate"/>ordateformat="MM/DD/YYYY"Thanks,Matt Shetzer
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
