I'd like to have Feet marks on the numbers that are associated with the divisions on the scale bar.Is this possible? How do I add them?Thanks,Tracey
A scale bar is a compilation (group) of graphic elements. If you select the scale bar and then select ungroup in the drawing menu, you can hack and whack on it till the cows come home. When you're done, select all the elements and group them back together.
