指示に従ってガスユーティリティネットワークを公開しようとしました Get started with the Gas Utility Network ConfigurationGet Started | ArcGIS for Gas<\/A> <\/P><\/P>しかし、以下のようなエラーメッセージが表示されました。<\/P>私のArcGIS Enterpriseの展開環境:<\/P> - Portal for ArcGIS 10.6<\/P> - ArcGIS Server site 10.6 + Utility Network extension <\/P><\/P><\/P><\/P>問題の原因について何かアイデアはありますか?<\/P><\/P>ありがとうございます。<\/P>Hung Truong<\/P>AltaGas Utilities Inc.<\/P><\/BODY><\/HTML>
<\/P>
ありがとうございます。<\/P>
Hung Truong<\/P>
Hi Vinay,
Have you resolved your issue(s)?
What I did to fix my issue was to rolled back ArcGIS Pro 2.1.
You cannot publish UN to Portal 10.6 using ArcGIS Pro 2.2. Or just wait for a few weeks until ArcGIS Enterprise 10.6.1 release.
I hope this helps.
Hung Truong
Can you please log a tech support incident for this?
I am also facing the same issue, The error in server log is:
Level Time Message SourceSEVERE Jul 6, 2018, 10:14:36 AM Error executing tool. PublishServiceDefinition Job ID: jd4d2f7ef93184b018aa31289db319c0c : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details. ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). Failed. Failed to execute (Publish Service Definition). System/PublishingTools.GPServerSEVERE Jul 6, 2018, 10:14:36 AM Delegate job failed. System/PublishingTools.GPServerSEVERE Jul 6, 2018, 10:14:34 AM Error executing tool. PublishServiceDefinition Job ID: jbd0147f18c3e43c783f0f511dbc0c4b7 : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details. ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). System/PublishingToolsEx.GPServerSEVERE Jul 6, 2018, 10:14:34 AM Failed to create the service.: Updating the server connection string for layer Gas Device failed. Attempted connection string was ENCRYPTED_PASSWORD=00022e68347042307051332f70792f41674672347666676f2f7372375a732f4133555257764171447067324c5335343d2a00;SERVER=localhost;INSTANCE="DSID=e12499c9-d26a-4b26-bc68-5ca4794dc002";DBCLIENT=sqlserver;DB_CONNECTION_PROPERTIES=localhost;DATABASE=NPU;USER=NPU9;AUTHENTICATION_MODE=DBMS;BRANCH=sde.DEFAULT. Table name is NPU.NPU9.PipelineDevice. Please verify the data exists on the server. System/PublishingToolsEx.GPServerSEVERE Jul 6, 2018, 10:14:34 AM DoAfterSDExtraction failed. System/PublishingToolsEx.GPServerSEVERE Jul 6, 2018, 10:14:34 AM SwizzleService failed. System/PublishingToolsEx.GPServer
Any help would be appreciated
Thanks
Vinay
Hung,
Where did you find the information out about ArcGIS Pro 2.2 isn't compatible with Enterprise 10.6 for the UN?
I'm having the same issue and my Esri partner doesn't know this either.
ArcGIS Enterprise 10.6.1 has been released and available for download yesterday. You may want to upgrade your enterprise to 10.6.1 in order to use ArcGIS Pro 2.2.
My “unofficial” contact at Esri told me yesterday that 10.6.1 was released. I’m about to embark on upgrading my recently installed 10.6 platform. Thanks for the information.
Anthony,
I am upgrading our enterprise to 10.6.1. Let me know how it goes with yours, we can share the experience (and/or pain).
Cheers
I am also upgrading to enterprise 10.6.1 and then I will try to implement Esri Gas Utility Network. Let's see how it will go.
