I wanted to see the type of holds on open jobs so i edited the definition query in WFM Admin. When I refreshed WFM my open job duplicated. Unsure why this occured or how to undo or delete duplicates.
The HOLD_TYPES was not removed from the FROM portion of the query. Once removed duplicates disappeared.
Hi Jake,
There is no easy undo once you have updated your query. Do you mind sharing your query? we can try to fix the duplicates.
Meggie
Hello,
Below is an example of the duplication that occurred in Workflow Manager, and the query from WFM Administrator.
