We will soon be releasing the first beta for the next generation of the ArcGIS API for JavaScript - 4.0 beta 1.
Until then, you can find some information in the UC Q&A | What is new and exciting about version 4.0 of the ArcGIS API for JavaScript?
For feedback and questions about the 4.0 betas, please post in the ArcGIS API for JavaScript forum and make sure to tag with 4.0beta.
Sounds exciting!
I am looking forward to 3D! Especially routing inside of a building! Will there be a way to route from inside one building to the inside of another?
Can't wait!
Hey Bjorn,
I can't wait for the release! On a side note, I put in a bug for a legend issue in v3.13 - BUG-000086150 - Legend fails with JSON data in ArcGIS API for Java..
The report indicates it's fixed in 3.14 - has 3.14 been officially released? I see the init.js script is available when I try to load it from the CDN.
Chris, that's not really related to 4.0 ... but yes, BUG-000086150 has been fixed for 3.14. And no, it hasn't been officially released.
Cool, thanks. I know it's unrelated to 4.0 - that's why I brought it up as a side note. I wasn't sure if there would be another 3.x version before 4.0 - if 3.14 was like a phantom staging branch, or something like that, since I couldn't find any press releases about 3.14.
Just wanting to make sure when we move to 4.0 it'll still be fixed!
3.14 is real (and coming soon) - there will still be several more 3.x version released. Until we release the "4.0 (final)" sometime next year, there will be both 4.0 beta versions and 3.x versions available in parallel.
Interesting ...
Will there be a Table of Contents widget in the JSAPI 4.0? Hoping. We don't need it for all apps, but for some, it's just helpful.
I have been waiting for that for eight years. Hope it's this one.
Chris...thank you for this good feature suggestion.
Bjorn Svensson if they use WAB's TOC code, can you pass along that they need to make it more hierarchical? If you close a group it does not uncheck the sublayers. Basically, it should use the behavior and GUI of Nianwei's AGS TOC. or the hierarchical menu system in any application does, whether it is ArcMap or WIndows Explorer. Closing a group should uncheck and close sublayers. Perhaps this was just a bug in the new WAB T.O.C. And so should patched in WAB too. Should I include screenshots or is that enough detail? And thank you! Looking forward to 4.0! Vectoring tiling, 3D etc sound awesome!
For feedback about WebAppBuilder, it's better to post in the WebAppBuilder forum:Web AppBuilder for ArcGIS
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
