If given a demo, could someone truly attest to the feasibility of replicating the same functionality in ArcGIS? Not a sales person, but a legit technology person.
- How does ArcGIS play with TypeSript?
- Will there be a DefinitelyTyped dictionary file for ArcGIS be available
- If this is using Dojo as an equivelant to require or MEF. Will those other downloaded js files also have dictionaries?
- Can I use GeoJSON to build my overlays for a map (mapping DMAs, Postal Codes, Sub-Postal Codes, etc.)
- How does the tool handle multi-polygon goegraphies?
- Can the tool support dynamic changes to the map and its contents, overlays, markers, iconography etc, fill colors, border colors, transparancy, opacity, etc.
Bootstrap integration with ArcGIS, you might want to check out this OS project I published a while back. It should jumpstart folks considerably.
