Anybody figure out why you can't use the basemap layer "Imagery Hybrid" in Collector? Whenever I try to download a map with this basemap, Collector on iOS crashes no matter what resolution you're trying to download. If I switch it to just the imagery basemap with no labels, it will download fine. Solution was found per this thread from 2018: https://community.esri.com/thread/213971-collector-crashes-in-ios
Hello Molly,
Are you still having issues with the app crashing? The imagery hybrid basemap downloads without issue for me.
Have you tried turning on the troubleshooting logs in Collector? These are found under the settings in the app > Troubleshooting. You can return and check the logs after a failure/crash and share them.
Also, please note the app version and what type of device you are using. Thanks!
Regards,
Colin
This is collector classic so no troubleshooting logs available.
Device is iPhone 11 Pro with lastest software updates. Version of Collector is 19.0.2
Molly,
The imagery hybrid basemap contains a vector tile reference layer (for the labeling). Classic does not support vector tiles so my guess is that this is causing the crashing.
Is there a reason you are still using Classic instead of the current version of Collector?
Classic allows you to place a point by just tapping on the screen. With Collector you have to click and drag the crosshairs making data collection MUCH slower. We are doing surveys where birds call rapidly, thus speed of collection is important.
Molly Foley, have you thought about using ArcGIS QuickCapture, if speed of collection is really important for this project?
You can vote up this functionality for the new Collector here: https://community.esri.com/ideas/17381
Also, as Katherine mentioned, Quick Capture is useful for speedy and simple collections.
I haven't investigated it very thoroughly, but at cursory glance it doesn't appear that it supports related data so unfortunately it wouldn't work for our purposes. I would love to be proven wrong though.
That's not really what we're looking for though. It's a 1-M relationship between points. The "many" part of that has to start off as a blank slate. It's really a problem of the slowness of placing the points, not filling out the fields.
