How do I change the layer label to be only what the name of the layer is?
I am using the Developer edition.
I want it to say Building Labels and not Interior_ - Building Labels
Ricky,
See my previous answer of this:
https://community.esri.com/thread/189607-remove-feature-layer-name-in-front-of-layers-in-arcgis-online-toc
Hi
An application in WAB uses a Web Map from the Portal (ArcGIS Online or Portal for ArcGIS), so the Layer name can be configured in the WebMap. The legend Widget reflect this change.
rscheitlin I should also add that I am adding the layer with the LocalLayer widget.
I have uncommitted out that section but it seems to work for the layer list not the legend.
Thank you
I am using the LocalLayer widget to add the layers so it does not use AGOL.
Rickey,
That is very odd because there is code in the LL widget to set the legend title to exactly what the layer name is in the LocalLayer widgets settings. What does your LL widget config.json look like?
rscheitlin I should also add that it is mostly using the LL widget. It is using my custom LL widget that I made a few years ago. It does not use the config.json.
I was able to get the LayerList widget to remove the unwanted labels just not the legend.
