I am in the process of migrating existing street centerlines to LG Road Centerlines and am at the point of cleaning up existing lines using Road Centerline topology. Here is my question: Must centerlines be constructed from straight line segments only? Or can they be comprised of straight line segments and arcs? I've looked at the Naperville example and it's curves all seem to be short line segments?
You are best off with segments. The curved lines, aka splines, can cause issues depending on how you are going to use them. Generally in a network they appear as a network build error.
