Just wondering if theres any way or by using HTML to resize popup windows in ARCgis portal? For example the popup window that appears when clicking on a map?
Tony,
If you are asking about AGOL then the answer is no. If you are talking about on premise Portal there is a possibility. And if you use WAB Developer then you can do just about anything you want.
