I tried using the feature to raster tool but i couldn't seem to understand the output.
Did you specify a polygon table field to use for the raster value? if not it just uses the object ID. If the field value was just population you would need to normalize it the data by area (pop / area) and grid on that field (density) instead of just population count. The cell values will then be more appropriate for this kind of analysis.
My maps are just regular polygon maps and when i try to use the weighted overaly analysis tool it wants everything in raster not polygon. Can anyone help me with this process?
