this.shapefileGL = new GraphicsLayer(); baseWidget.map.addLayer( this.shapefileGL); this.shapefileGL.addEventListener(LayerEvent.UPDATE_START, updateStart); this.shapefileGL.addEventListener(LayerEvent.UPDATE_END, updateEnd); this.shapefileGL.addEventListener(LayerEvent.LOAD, loaded); private function updateStart(event:LayerEvent):void { LogUtil.getLogger(ShowShapefileMediator).info("updateStart"); } private function updateEnd(event:LayerEvent):void { LogUtil.getLogger(ShowShapefileMediator).info("updateEnd"); } private function loaded(event:LayerEvent):void { LogUtil.getLogger(ShowShapefileMediator).info("loaded"); }
<s:Label text="Layer Logs:" y="780"/> <s:HGroup width="100%" height="50%" y="800"> <s:TextArea width="100%" height="90%" id="log" /> </s:HGroup> private function addLog(message:String):void { log.text = StringUtil.substitute("{0}\n\n{1}", message, log.text); } protected function onLayerLoadError(event:LayerEvent):void { addLog(StringUtil.substitute("Error on loading layer {0}", event.layer.name)); nonLoadedCount++; var mapLayersCount:int = ArrayCollection(myMap.layers).length; if (mapLayersCount == (nonLoadedCount + loadedCount)) { addLog(StringUtil.substitute("Loaded: {0} of {1} layers\n {2} layers fault on loading.", loadedCount, mapLayersCount, nonLoadedCount)); } } protected function onLayerLoad(event:LayerEvent):void { addLog(StringUtil.substitute("{0} is loaded", event.layer.name)); loadedCount++; var mapLayersCount:int = ArrayCollection(myMap.layers).length; if (mapLayersCount == (nonLoadedCount + loadedCount)) { addLog(StringUtil.substitute("Loaded: {0} of {1} layers\n {2} layers fault on loading.", loadedCount, mapLayersCount, nonLoadedCount)); } } protected function onLayerUpdateStart(event:LayerEvent):void { addLog(StringUtil.substitute("{0} update started", event.layer.name)); if (updateStartedCount == updateEndedCount) { updateStartedCount = updateEndedCount = 0; // reset } updateStartedCount++; } protected function onLayerUpdateEnd(event:LayerEvent):void { addLog(StringUtil.substitute("{0} update ended >> update success = {1}", event.layer.name, event.updateSuccess)); updateEndedCount++; if (updateStartedCount == updateEndedCount) { addLog("All layers are updated"); } }
private var shapefileGL:GraphicsLayer; [Bindable] public var polygonFillSymbol:SimpleFillSymbol = new SimpleFillSymbol("solid",0,1,new SimpleLineSymbol()); private function fileLoaded(result:Array):void { for each(var i:Geometry in result) { switch (_shapeFileLoader.shpType) { case ShpType.SHAPE_POLYGON: { graphic = new Graphic(i, this.polygonFillSymbol); this.shapefileGL.add(graphic); } } } }
protected function fillStyle_changeHandler(event:IndexChangeEvent):void { polygonFillSymbol.style = fillStyle.selectedItem.style; }
