HELLO, can anybody tell me where to change the background color for a customized widget I built? Thanks,
Thanks Robert for your response. I have attached a screen shot. I used Lauchpad theme and I want to change the default white background color to other color.
Alex,
that is a very subjective question... Is your widget using a tab container? What theme are you using? Probably would be better to attach a screenshot pointing to exactly what you are trying to change color for.
Add this css rule to your [install dir]\server\apps\[app#]\themes\LaunchpadTheme\common.css
<SPAN class="selector token">.jimu-panel.jimu-launchpad-panel</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">background-color</SPAN><SPAN class="punctuation token">:</SPAN> blue<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Worked, always! Thanks, Robert.
