こんにちはGeoNet、<\/P>
<\/P>
ジオプロセシングサービスを公開する必要がなければ、ArcGIS Enterprise 10.6.1のままで、ArcGIS Desktopを10.7.1にアップグレードしても問題ないでしょうか?<\/P>
ありがとうございます!<\/P><\/BODY><\/HTML>
You can still use ArcMap with a previous version of ArcGIS Enterprise. However, if there is new functionality at version 10.7.1 within ArcGIS Server, you will need to upgrade your server site.
Check the FAQs here for more compatibility questions and answers:
Common questions about version compatibility
Hope this helps!
Thank you Andrew.
