I am beggining to understand how to better customize apps made in WAB, but I can't seem to find where the map class is created, so I can access and changes it's properties as seen here Map | API Reference | ArcGIS API for JavaScript 3.17
My actual goal is to change the infoWindow property to a custom one that also shows related tables (as seen here Popup with related fields | ArcGIS API for JavaScript 3.17 ) and is moveable (if possible)
Samuel,
The map is created in the jimu/MapManager.js
Thanks Robert, I see now.
Considering that I want to customize the on click popup, how would it be advised to do it? Editing the MapManager?
Nope that would be the PopupMnager.js
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
