anybody else experiencing ago and other apps performance this morning. We can't even load collector and ago won't open if it does it is painfully slow
ArcGIS Online Health Dashboard
So this map has gone viral in the media, Operations Dashboard for ArcGIS , I wonder if this is the cause of the performance problems?
Hi Vanshika,
Are there any updates on this issue?
Rory
I hope this is fixed sooner for our day to be more productive. Thanks.
we are also having the issues, been slow all day and now its stopped working.
Stu
From ESRI:
Good morning! Thank you for bringing the issue to our attention! This is Vanshika from ESRI Technical Support Services, writing in reference to case #. I have taken ownership of this case and will be working with you on this issue. I would like to inform you that the Operations team is aware about the performance issue of ArcGIS Online hosted feature services and they are actively investigating other reports. I will keep you posted as soon as we have an update from the team and sincerely apologize for the inconvenience due to the behavior.
Thomas:
Do your nightly scripts work directly with AGOL (e.g. Do you overwrite data that is hosted in AGOL on a nightly basis)?
What interesting is the outage started many hours ago, yet the dashboard is showing it started at 6 AM PST. Wonder how "automatic" the health checks are, and how reliable the dashboard is?
Thanks Lester. I couldn't even get on the health dashboard earlier.
The ArcGIS Online Health Dashboard is acknowledging the problem now: ArcGIS Online Health Dashboard
Yes, I have been having the same issues with trying to sign in to ArcGIS Pro using ArcGIS Online logins.
We are seeing problems as well- slowness logging in and using web maps and errors when trying to open ArcGIS Pro. Our on-site Portal is running fine.
Yes, we have been experience intermittent issues, a lot of "bad gateway" yet ArcGIS Online Health Dashboard shows everything is fine. The issue started late last night, a lot of my nightly python updates failed.
